1990 Ford Mustang Overheating
MISSBAMA
  • 1990 FORD MUSTANG
  • V8
  • 5,000 MILES
Hey there I drove this car all last year the new motor only has about 5 to 7 thousand miles. Most everything else has also been replaced. Last fall the engine started overheating. I had the alternator tested and it runs at 14amps. The overheating was only happening like every 2 weeks and it would run hot and then gauge would fall back down then run hot again. Eventually it would heat up rather quick maybe after 2 or 3 miles. Then the check engine light came on and it's been parked since december07. I started it today and let it run for about 10mins and it started getting hot and the guage was up to the o on normal and the car was parked the whole time. I think it's the fan clutch. I am taking it to the shop in 4 days and being a female I don't want to get taken for a water pump, blown head gasket or blinker fluid, LOL. Please help!
Wednesday, April 30th, 2008 AT 11:02 PM
LEGITIMATE007
  • 5,121 POSTS
What year is this engine? If its a newer engine or at least an 89, I would test /replace the engine coolant temperature sensor first. Because a faulty one will cause the same symptoms, I don't want to see you get taken either, some of those guys are savages and will do anything for an extra buck or two
Thursday, May 1st, 2008 AT 6:18 AM
2CARPRO JACK
  • 11,533 POSTS
Does it go past the "o" on normal? That isnt really hot. Have a thermostat put in it and go from there
Thursday, May 1st, 2008 AT 7:51 AM
LEGITIMATE007
  • 5,121 POSTS
Yes of course, thermostat then ect.
Thursday, May 1st, 2008 AT 9:00 AM
