1990 Ford Mustang check engine light
LILBROOKLYN
  • 1990 FORD MUSTANG
Electrical problem
1990 Ford Mustang V8 Two Wheel Drive Automatic
i have several codes im trying to figure out what means code 11. Code13. Code34and code 19 I need the meaning and what the issues could be its a 1990 5.0 mustang lx obd 1 if I could get help it would be majerly appreciated
Friday, September 3rd, 2010 AT 12:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Code 11 is just a pass code which indicates that there are no recorded service codes in that portion of the test and that the system passes that portion of the test.
Code 13 indicates engine could not be controlled within lower RPM range during self-test. Possible causes for this code include vacuum leaks, incorrect idle setting, throttle plates open, stuck throttle linkage.
Code 19 indicates that with ISC off, engine RPM dropped below self-test limit (approx. 600 RPM). Possible causes are incorrect idle, throttle body/air inlet contamination and/or engine below normal operating temperature.
Code 34 indicates that the EGR valve and/or EVP is not fully seated in the closed position. Most likely culprit is faulty EGR valve.
Friday, September 3rd, 2010 AT 2:45 PM
