1989 Ford Mustang CAR WONT TURN OVER
CLAMPER
  • 1989 FORD MUSTANG
Engine Mechanical problem
1989 Ford Mustang 4 cyl Two Wheel Drive Manual
MY CAR WONT TURN OVER. I TESTED THE BATTERY IT SEEMS TO BE GOOD, I BENCH TESTED THE STARTER AND IT IS GOOD, I REPLACED THE STARTER SELINOID. 3 WEEKS AGO I REPLACED THE IGNITION MODULE AND THE IGNITION SWITCH.
THE PROBLEM IS WHEN I TRY TO START THE CAR THE SELINOID WILL JUST MAKE A BUZZING NOISE. WHAT ELSE CAN I DO?
Monday, June 15th, 2009 AT 12:50 PM
How did you test the battery?
Double check the starter solenoid if okay could be the starter overrunning clutch is slippping, also connection problems.
Monday, June 15th, 2009 AT 2:21 PM
CLAMPER
BATTERY MEASURED 12.4 AT THE POSTS. HOW CAN I MEASURE VOLTS GOING TO THE STARTER, UNDER THE LOAD. CAN I BYPASS THE SOLENOID TO TEST THE SYSYTEM.
Monday, June 15th, 2009 AT 3:01 PM
Short out the starter relay S small terminal to the battery terminal on the relay-did the starter engage the engine
Monday, June 15th, 2009 AT 5:34 PM
