Transmission problem
1988 Ford Mustang Two Wheel Drive Automatic 68000 miles
After sitting for just short of two years without being driven, installed fresh battery and started easily. After initial drive noticed transmission fluid running out at front of transmission. The car drives normally, changes gears smoothly. After finding the fluid leaking, have not driven again. No leaks of any kind when originally parked.
The engine is the 2.3L 4 cyl.
Question: Is this most likely the seal has hardened and is no longer sealing? If so, how hard to replace?
Thank you for your service.
Jul 22, 2009 at 8:48 PM
