1966 Ford Mustang fluid leak
124,000 MILES • 6 CYL • 2WD • AUTOMATIC
IMRCR
I have the above convertable mustang and it is leaking fluid which I believe to be transmission fluid. What might be causing this in an old car? What should I check and if necessary what type of specialist should I take it to? Thankyou
Jul 16, 2009 at 9:07 AM
  • 31,937 POSTS
Hi there,
the most common place is normally the pan gasket, this is a simple job, but can be messy, make sure that the pan is very clean when replacing it and don't over tighten the bolts if it has a cork type gasket.
mark (mhpautos)
Jul 16, 2009 at 2:13 PM
