1987 Ford Mustang fuel diagnostic
1935MASTER
  • 1987 FORD MUSTANG
Engine Mechanical problem
1987 Ford Mustang V8 Two Wheel Drive Automatic
vehicle will not stay running
Friday, May 21st, 2010 AT 10:58 PM
Check the fuel pressure if its within specs if okay clean out the idle air control valve also the MAF sensor with an approved cleaner and test the throttle position sensor.
Friday, May 21st, 2010 AT 11:04 PM
KEVDUDE55
Check Your MAP sensor, if the car is spewing black smoke and running like an old tractor (you know, putt-putt-putt)
Its usually the map sensor, or a vacuum leak.
Wednesday, June 2nd, 2010 AT 2:03 AM
