1985 Ford Mustang will not start
FERSUREIAN
  • 1985 FORD MUSTANG
Engine Mechanical problem
1985 Ford Mustang 4 cyl Two Wheel Drive Manual
my timing was all out. But I re-timed it. Still will not start. Put the plug wires on right plugs. The distriburtor might be out 180 degrees. Im not sure though. I can't think of anything else. Please help
Friday, May 28th, 2010 AT 9:37 AM
KEVDUDE55
Set engine to TDC on the compression stroke on the first cylinder, pull your distributor, set rotor to 1 cyl.
Back of 10*(retard the timing 10 degrees), then try to crank, if it does not start check the spark on the plugs, there are a few ways to do this, just get a spark tester.
If there is spark its a fuel problem.
Check your fuel pressure, if it is a carbed engine, try to use starting fluid, if it does not sputter, or try to turn over, then its most likely the carb itself and/or a spark issue.
If it sputters a little, or trys to start and dies, then you most likely have a fuel pump out, or a clogged fuel filter.
Pray its the fuel filter, fuel pumps are a pain to get too, due to the need to drop the fuel tank.
Check your compression now, if you have a compression tester, anything over 100lbs is more than adequate.
Wednesday, June 2nd, 2010 AT 2:01 AM
