HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Mustang
Engine
Symptoms
Not Cranking Over
SPONSORED LINKS
1985 Ford Mustang WANT CRANK
JARVISWALLACE
MEMBER
1985 FORD MUSTANG
V8
2WD
MANUAL
10,000 MILES
If a car spin over but will not crank what kind of problem is that
Sunday, May 30th, 2010 AT 10:07 PM
BLUELIGHTNIN6
MECHANIC
Spin over and crank is same thing, you mean the engine is cranking but will not fire up? If so then need to check fuel pressure and spark
SPONSORED LINKS
Sunday, May 30th, 2010 AT 10:14 PM
JARVISWALLACE
MEMBER
Sunday, May 30th, 2010 AT 10:17 PM
JARVISWALLACE
MEMBER
How can I check the fuel pressure
Sunday, May 30th, 2010 AT 10:59 PM
BLUELIGHTNIN6
MECHANIC
Check out our article on it at
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Sunday, May 30th, 2010 AT 11:02 PM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
Engine Will Not Crank Over?
Car Was Fine, Then It Suddenly Would Not Start. The Battery Is Fine, No Clicking, But It Will Not Crank At All. Unfortunately, This...
Asked by
Shayne Canady
1 IMAGE
2001
FORD MUSTANG
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
Engine Wont Turn Over At All, When I Turn To Ignition...
Hi, I Am A New Ford Owner And Bought This Car Second Hand And Was Running Fine Once I Got It And Then About Five Months Or So Later, It...
Asked by
BigMike101
1 ANSWER
1983
FORD MUSTANG
Wont Start, No Crank, Happens Randomly
Bought Car 2 Months Ago. After 2 Weeks, Wouldnt Start After Driving Awile. Started After 5 Or So Minutes. Week Later, Same Thing, Except...
Asked by
techmastersean
1997
FORD MUSTANG
Will Not Crank
I Place Two Different New Batteries In Car. On The Last Battery Put In It Cranked Twice, Then It Clicked Then It Died. Will Crank With A...
Asked by
Laura Sellars
1999
FORD MUSTANG
I Just Put In A New Fuel Pump In A 95 Ford Mustang But...
I Just Put In A New Fuel Pump In A 95 Ford Mustang But The Car Wont Crank Up Whats Wrong With The Car?
Asked by
maserati
1995
FORD MUSTANG
VIEW MORE
SPONSORED LINKS
Starter Replacement
Battery Replacement Ford
Battery Test
Online car repair manuals
