1984 Ford Mustang
ROLVEGA76
  • 1984 FORD MUSTANG
  • 6 CYL
  • 178,000 MILES
How can you figure out whats wrong with my car. What it does that you can run for 3 days, and then it completed drain the battery low. I change the alternator and it still does the same thing. What else can I see what's wrong with it. Please help!
Wednesday, August 20th, 2008 AT 4:54 PM
  • 31,937 POSTS
Hi there,
have the battery fully charged and load tested, this is the only true test for a faulty battery, then get your mechanic to do a currant draw test this will show and current drain from a circuit that is causing a problem may be a stuck or faulty relay somewhere, start here.
Mark (mhpautos)
Wednesday, August 20th, 2008 AT 5:51 PM
