For acooling system to work properly it cant have any leaks, it relies on pressure in the system to keep the coolant from boiling. The leak at ehfirewall+ thesmoke in thecar sounds liek the heater core is leaking. For now just unhook it at the firewall and use a connector to connect the two ends together. You will also need to have the radiator pin hole fixed. If thefluid is orabge colored it is most likely rust from the previous owner using water to keep it full. Have the engine flushed and the thermostat replaced. Fill it with good coolant with all leaks repaired and see where you stand from there
SPONSORED LINKS
Friday, March 12th, 2010 AT 8:06 AM
