1968 Ford Mustang slight blue smoke from tail pipe at while
1968 FORD MUSTANG
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
LLOYD1
at idle i slight blue smoke from tail pipe.
Once driving after 15 minutes get more constant
blue smoke.
can you help with advise
Jan 7, 2008 at 7:32 AM
MERLIN2021
  • 17,250 POSTS
Usually when smoke increases while driving the piston rings are allowing too much oil to blow by them, remove the oil cap on the valve cover, does it smoke out of the hole? Do a compression test to see how the engine is.
Jan 7, 2008 at 7:36 AM
