1968 Ford Mustang overheating
MARKMANIS
  • 1968 FORD MUSTANG
Engine Cooling problem
1968 Ford Mustang V8 Two Wheel Drive Automatic
i have put in a new radiator, waterpump, thremostat and its still overheating, the engine has just been rebuilt, I have been told many different things from the head gaskets may be on wrong adjust the lean in the carburator, the timing may be off, I hope u can help me out thank you
Wednesday, May 26th, 2010 AT 8:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Is the cooling fan working? If so it could be cracked head gasket. Need to have compression checked in cylinders
Wednesday, May 26th, 2010 AT 9:32 PM
KADESPA
Do you have a constant voltage regulator? I am having a problem with my temp guage reading hot while the actual water temp is around 185 degrees. I have been told it might be the CVR as mentioned above.
Wednesday, June 2nd, 2010 AT 1:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Have you checked the coolant temp. Sending unit/sensor?
Wednesday, June 2nd, 2010 AT 1:43 AM
