Recheck the thermostat and make sure the heater control valve works and the heater core is not clogged, and you smelling coolant could mean the heater core is leaking. Radiator could be clogged-up
After the car has run for a while and then is turned off the water pump leaks coolant, and this is normal you have to replace the water pump.
SPONSORED LINKS
Saturday, November 7th, 2009 AT 10:58 PM
