1968 Ford Mustang How to avoid tire rubbing
130,000 MILES • V8 • 2WD • AUTOMATIC
SHADOW25
I have a 1968 mustang that has slighlty bigger tires than stock. How do I avoid the occasional tire rub that happens when I hit a bump in the road. For some reason it only happens on the right side. Do I replace the springs or shocks?.
Mar 1, 2008 at 10:14 PM
MERLIN2021
  • 17,250 POSTS
Springs control ride hieght...
Mar 1, 2008 at 10:17 PM
SHADOW25
Would I go to a stronger spring ?. Right now it looks like it has 5 leafs. Can someone point me in the right direction on where to purchase new leaf springs?.
Mar 2, 2008 at 9:03 AM
MASTERTECHTIM
  • 4,750 POSTS
my suggestion would be is to go to a spring shop and they can add a leaf or rebend them, check that out before replacing them.
Mar 2, 2008 at 9:21 AM
MERLIN2021
  • 17,250 POSTS
If it's only the rear springs that meed help, you can also put in a set of air shocks, or load levelers.
Mar 3, 2008 at 4:36 AM
