1967 Ford Mustang engine would not start
CHARLES HUANG
  • 1967 FORD MUSTANG
  • V8
  • 60,000 MILES
I have a V8, 289, Sometime the car would not start, I put in a new battery, the oil level is ok. I put in a rebuilt engine 15,000 miles ago.
what else can it cause not to start
Thursday, February 28th, 2008 AT 2:39 PM
MERLIN2021
  • 17,250 POSTS
Is it cranking? Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
Thursday, February 28th, 2008 AT 4:28 PM
