1966 Ford Mustang Won't start with ignition
MOPAR68DON
  • 1966 FORD MUSTANG
Electrical problem
1966 Ford Mustang V8 Two Wheel Drive Automatic unknow miles
My mustang has a new battery, starter, starter relay, ignition and alternator. It will not start by turning the key, it with start by turning the key on and crossing the starter relay on the fender well. Can you please advise where I should search next?
Thxs. Don
Monday, July 5th, 2010 AT 10:55 PM
DOCFIXIT
  • 18,828 POSTS
Have you checked neutral safety switch? Try start in neutral
Tuesday, July 6th, 2010 AT 12:13 PM
MOPAR68DON
Yes, I did try and start it in neutral and still nothing. Do you think the neutral safety switch is out?
Tuesday, July 6th, 2010 AT 6:29 PM
DOCFIXIT
  • 18,828 POSTS
Yes it prohibits power to solenoid if car in gear. This is going back to my teenage years but believe on trans find switch think three wires remove with test light find power on a terminal believe jumper two outside. If starts replace switch
Wednesday, July 7th, 2010 AT 9:45 AM
MOPAR68DON
I will give that a try, might have to wait a while, it has been so hot here in Phoenix, I about die in the heat anymore, getting old. LOL I will let you know what I find once it cools down a little bit.
Thxs. Don
Wednesday, July 7th, 2010 AT 8:22 PM
