1965 Ford Mustang accelaration
ELPIBBE
  • 1965 FORD MUSTANG
  • 6 CYL
  • 25,000 MILES
Engine 20000 miles
Transmission brand new
just changed carburator
Timing at 12 degrees
If I punch it it stalls, if I accelarate slowly it wil run very smooth but it lacks power. Before I changed transmission and carb if I punched it would burn "a little rubber"
What am I not doing right?
Please help.
Thursday, January 29th, 2009 AT 4:07 PM
Check your fuel pressure and also double check if the accelerator pump circuit is functioning properly and the power valve on it
Double check the dwell angle of the distributor ignition contact point
What is this? Is it a 289CID
Thursday, January 29th, 2009 AT 4:46 PM
ELPIBBE
No its a I6 3.3l, and you lost me with the answer.
Electronic ignition
Thursday, January 29th, 2009 AT 4:51 PM
During my time there's no such thing as 3.3L engine for a 1965 ford stang -what year is it/model were dealing here Be specific
Thursday, January 29th, 2009 AT 5:54 PM
ELPIBBE
Sorry your wrong, its a inline 6cyl 200 cid 3.3l what I have, that year there was a 170cid 2.8l also made in an inline six.
Thursday, January 29th, 2009 AT 6:00 PM
My mistake normally when I go under one of them its a 8 banger 289 original -okay here we go, lets do the what I've suggested earlier and report back asap-also test the coil primary and secondary windings resistances, and the distributor pick-up coil resistances and check for short to ground.
Do you have a vacuum advance diaphragm on the distributor?
Thursday, January 29th, 2009 AT 8:33 PM
