1999 Ford Mondeo clunking noise
1999 FORD MONDEO
ARCHAEOLOGYID
Noises problem
1999 Ford Mondeo 4 cyl Front Wheel Drive Manual
there has been a tinny metalic rattle coming from what seems to be the front of my mondeo for a few months now, sounding almost like a loose bracket on exhaust but after being twice on ramps & thoroughly searched inspected there is nothing loose anywhere. Recently in the last 2 weeks there is now a clunk coming from again sounds like the front, like cv joint noise but this happens when starting off going forward & reverse...a few inches into pulling away going in straight line there is an initial quite load clunk...same thing when stopped & starting to reverse...i have not heard this clunk while turning like you would a cv joint ...could this be related to the tinny rattling noise which is constant now even though prior to this clunk there the rattling didnt affect the mechanics or mobility of my car in any way, no vearing to left or right suspension is fine no vibration or wobbling to stearing etc...also i believe the water pump has gone due to there being no presure when squeezing the top hose, could the rattle be that?...seems very load.
Jul 18, 2009 at 10:36 AM
DAVE H
  • 13,384 POSTS
could have been the bearings in the water pump .. but i would have expected a mechanic to hear this !!
Aug 11, 2009 at 9:56 PM
NOCKOFFNIGEL
[quote:7b159b0433="archaeologyid"]Noises problem
there has been a tinny metalic rattle coming from what seems to be the front of my mondeo for a few months now, sounding almost like a loose bracket on exhaust but after being twice on ramps & thoroughly searched inspected there is nothing loose anywhere. Recently in the last 2 weeks there is now a clunk coming from again sounds like the front, like cv joint noise but this happens when starting off going forward & reverse...a few inches into pulling away going in straight line there is an initial quite load clunk...same thing when stopped & starting to reverse...i have not heard this clunk while turning like you would a cv joint ...could this be related to the tinny rattling noise which is constant now even though prior to this clunk there the rattling didnt affect the mechanics or mobility of my car in any way, no vearing to left or right suspension is fine no vibration or wobbling to stearing etc...also i believe the water pump has gone due to there being no presure when squeezing the top hose, could the rattle be that?...seems very load.[/quote:7b159b0433]
Sep 18, 2009 at 9:06 AM
NOCKOFFNIGEL
[quote="Nockoffnigel"][quote:9ac4f10136="archaeologyid"]Noises problem
there has been a tinny metalic rattle coming from what seems to be the front of my mondeo for a few months now, sounding almost like a loose bracket on exhaust but after being twice on ramps & thoroughly searched inspected there is nothing loose anywhere. Recently in the last 2 weeks there is now a clunk coming from again sounds like the front, like cv joint noise but this happens when starting off going forward & reverse...a few inches into pulling away going in straight line there is an initial quite load clunk...same thing when stopped & starting to reverse...i have not heard this clunk while turning like you would a cv joint ...could this be related to the tinny rattling noise which is constant now even though prior to this clunk there the rattling didnt affect the mechanics or mobility of my car in any way, no vearing to left or right suspension is fine no vibration or wobbling to stearing etc...also i believe the water pump has gone due to there being no presure when squeezing the top hose, could the rattle be that?...seems very load.[/quote:9ac4f10136]
Sep 25, 2009 at 8:30 AM
NOCKOFFNIGEL
jjj
Sep 27, 2009 at 9:08 AM
NOCKOFFNIGEL
[quote:ff9d5b9f51="archaeologyid"]Noises problem
there has been a tinny metalic rattle coming from what seems to be the front of my mondeo for a few months now, sounding almost like a loose bracket on exhaust but after being twice on ramps & thoroughly searched inspected there is nothing loose anywhere. Recently in the last 2 weeks there is now a clunk coming from again sounds like the front, like cv joint noise but this happens when starting off going forward & reverse...a few inches into pulling away going in straight line there is an initial quite load clunk...same thing when stopped & starting to reverse...i have not heard this clunk while turning like you would a cv joint ...could this be related to the tinny rattling noise which is constant now even though prior to this clunk there the rattling didnt affect the mechanics or mobility of my car in any way, no vearing to left or right suspension is fine no vibration or wobbling to stearing etc...also i believe the water pump has gone due to there being no presure when squeezing the top hose, could the rattle be that?...seems very load.[/quote:ff9d5b9f51]
Sep 27, 2009 at 9:12 AM
