1984 Ford LTD Valve Cover Oil Leak
PSHELDONFAMILY
1984 Ford LTD Wagon, 111,000 miles. 3.8 engine.
Is there an oil additive that will slow down oil leaks around the valve gaskets? I don't want to get the whole thing replaced for such a slow leak, but the oil smoke on the headers can be very distracting.
Hope you can help.
S
Aug 7, 2007 at 8:33 AM
SERVICE WRITER
  • 9,123 POSTS
Not only distracting but dangerous if it starts on fire.
RE-torque the valve cover bolts. IF you need a spec let me know. When the motor is cold spray it down with brake clean to get the residue off.
You can add a product called lucas. You can switch the oil to 20W50 in addition.
Aug 7, 2007 at 8:45 AM
Suggested Repair
Re-torque the valve cover bolts when the engine is cold, then clean oil residue with brake cleaner. A Lucas oil additive and switching to 20W50 oil may also slow the leak.
Conversation Summary
The owner of a 1984 Ford LTD wagon with a 3.8 engine asked about an oil additive to slow a valve cover gasket leak rather than replacing the gaskets. The expert warned that oil on the headers is a fire risk and recommended re-torquing the valve cover bolts, cleaning residue with brake cleaner when cold, adding Lucas, and switching to 20W50 oil.
