1979 Ford LTD Dies After Warm-Up
GREG P
The car will start fine when cold. Run for about an hour or 2 then just die. Let it sit overnight and it will start right up. I have replaced the fuel filter and ignition control module. Still doing the same thing. While the car is warming up I did notice an exhaust leak coming from around the front doors. Could an O2 sensor or an EGR valve be causing this problem?? I have only had this car for 3 days. I need it for work, but I am afraid to drive it for fear of breaking down. PLEASE HELP!!!!!!
Feb 17, 2007 at 11:49 PM
SIRGIBBY
  • 32 POSTS
Try replacing the ignition coil. It sounds to me that when it runs for awhile the coil gets hot and then breaks down and is unable to keep enough spark going to run the car. Once it cools down its ok till it heats up
Feb 20, 2007 at 6:40 PM
  • 75,988 POSTS
Could be ignition coil or a fuel pump going southbound
O2 sensor w/n do that/Try this disconnect the vacuum hose from the EGR and go for the ride.
Also try this when it dies immediately check for spark and fuel then comeback
Feb 20, 2007 at 9:18 PM
Suggested Repair
Suspect a heat-related ignition coil or a failing fuel pump. An oxygen sensor is unlikely to cause this. Disconnect the EGR vacuum hose and test-drive; when it dies, immediately check for spark and fuel.
Conversation Summary
A 1979 Ford LTD with a 351W starts cold, runs one to two hours, then dies, and restarts after cooling overnight. The fuel filter and ignition control module were already replaced, and an exhaust leak was noted. Replies point to a hot ignition coil or failing fuel pump, say an oxygen sensor would not cause this, and suggest disconnecting the EGR vacuum hose and checking spark and fuel right after it stalls.
