when to change Brakes?
JDAN
I have a 2004 Ford Focus with approx. 50,000kms. After my last oil change at the dealership I was told I needed new front brake pads & rotors. I noticed no squeeling, pulling to the side or shudders while braking, but they told me I had poor wear on them with the front brake pads having 6mm remaining. What does this mean? How many milimeters can be left before the pads need to be changed? I did get them done somewhere else with a certified mechanic and he told me they did not need to be done yet, they still had lots of pad, were not rusting or worn. But i am curious about the 6mm thing.
Sep 19, 2007 at 8:16 AM
MERLIN2021
  • 17,250 POSTS
What they are saying is the lining material has worn to about the thickness of the steel plate they are glued to...approxiamatly 6mm thick!
Sep 19, 2007 at 8:22 AM
