2002 Ford Focus Hard Shift Into 2nd
JBRAMHALL
hi, i have a 2002 ford focus zx3, mileage about 82000. for the past couple of months i've been having a hard time shifting into 2nd gear, only. if i would shift into it normally it grinds the gears. but i've found out that if i ease into the gear and wait for the rpms to go down to about 1000x the gears won't grind, at least all the time. the clutch is stock still and every other gear is perfectly fine. i don't have much money so taking it into the mechanic to try and find out what the problem is isn't really an option for me right now. i'm just wondering if someone can help me so i can try and fix it myself. any thoughts are welcomed. thanks.
Jun 5, 2007 at 6:29 AM
TAURUSWHEEL
  • 718 POSTS
probably have to pull it apart, it isn't for the faint of heart,, if all others are nice and quiet, probably takes the clutch out of the issue,, also check your shift cables or linkage to make sure nothing is affecting them..
Jun 5, 2007 at 9:33 AM
Suggested Repair
Check the shift cables and linkage for anything that could affect second gear. Because the other gears shift normally, the clutch is less likely the cause. If the linkage is fine, the transmission may need to be disassembled, which is a difficult repair.
Conversation Summary
The owner of a 2002 Ford Focus ZX3 with about 82,000 miles reports grinding only when shifting into second gear. Easing into the gear and waiting for engine speed to drop reduces the grinding, while every other gear works normally and the clutch is original. The expert says the clutch is probably not the issue and recommends checking the shift cables or linkage; otherwise the transmission may need to be taken apart.
