2004 Ford Focus High Beams Stay On
ANNEWOOLFOLK
My 2004 Ford Focus has about 46K miles on it. I went to turn the knob to turn on my low beams and my high beams indicator came on when I turned on the low beams. So I thought, Oh, I left my high beams on, so I flicked the switch to turn off the high beams but the high beams indicator did not go off. So I tried the whole process again, and I belive I hava low beams, but my friends say it is my high beams. When I changed the beams it appears that the high beams lights come on, but the indicator does not go off at all. What can be wrong? :?
Aug 13, 2006 at 10:23 AM
MIKEYBDMAN
  • 623 POSTS
[quote:f17528e077="annewoolfolk"]My 2004 Ford Focus has about 46K miles on it. I went to turn the knob to turn on my low beams and my high beams indicator came on when I turned on the low beams. So I thought, Oh, I left my high beams on, so I flicked the switch to turn off the high beams but the high beams indicator did not go off. So I tried the whole process again, and I belive I hava low beams, but my friends say it is my high beams. When I changed the beams it appears that the high beams lights come on, but the indicator does not go off at all. What can be wrong? :?[/quote:f17528e077]
You have a high beam relay, and maybe it is stuck keeping the high beams on at all times. If the car is still under warrenty, I would let the dealer figure it out for you.
Aug 13, 2006 at 10:35 AM
Suggested Repair
Check the high-beam relay, which may be stuck and keeping the high beams on. If the vehicle is still under warranty, have the dealer diagnose it.
Conversation Summary
The owner of a 2004 Ford Focus says the high-beam indicator comes on with the low beams and will not turn off, while others say the high beams are actually on. An expert suggests a stuck high-beam relay may be keeping the high beams on and recommends dealer diagnosis if the car is still under warranty.
