2001 Ford Focus Stalls in Park
IVYLYNN2
I recently bought a 2001 Ford Focus (V4) with 80,000 miles. When driving the car with the defrost on the car will stall out once it is put in park. I was wondering if this is an alternator issue or if I just need to have the idle valve cleaned/replaced.
Oct 27, 2007 at 9:33 AM
BMRFIXIT
  • 19,053 POSTS
[quote:b972c1372a="ivylynn2"]Hello,
I recently bought a 2001 Ford Focus (V4) with 80,000 miles. When driving the car with the defrost on the car will stall out once it is put in park. I was wondering if this is an alternator issue or if I just need to have the idle valve cleaned/replaced.[/quote:b972c1372a]
i would have the battery and charging system checked
making sure alternator checked under load
i would also look for another symptom
(put ac on wipers lights)does it stall
cleaning idle air is a plus
Oct 27, 2007 at 10:25 AM
Suggested Repair
Check the battery and charging system, and test the alternator under load. See whether the stall also occurs with the A/C, wipers, and lights on. Cleaning the idle air control is also recommended.
Conversation Summary
The owner of a 2001 Ford Focus with 80,000 miles says the engine stalls when shifted into park after driving with the defroster on, and asks whether the alternator or idle valve is the cause. The expert recommends checking the battery and charging system with the alternator tested under load, noting whether other electrical loads also cause stalling, and cleaning the idle air control.
