2002 Ford Focus Low-Side A/C Port
BCUROLE
I am trying to add freon to my 2002 Ford Focus. I can find the high valve but not the low, which is the one I need. Where can I find the low line valve?
Mar 15, 2006 at 2:06 AM
NOS
  • 320 POSTS
follow the big line. they put the tap in the suction side which is the big line most times it is by the receiver dryer, or some place in the big line or right at the comrressor on the big S side. fill only from suction side uless you really want to loose a hand never go above 250psi on a good warm day. heat makes high side pressure and can blow a line so be very carefull. ( NOS )
Mar 15, 2006 at 11:30 AM
Suggested Repair
Find the low-side service port on the larger suction line, often near the receiver-dryer, along that line, or at the compressor suction side. Charge only from the low/suction side, never the high side, and on a warm day keep pressure at or below about 250 psi so heat does not raise high-side pressure enough to rupture a line.
Conversation Summary
The owner of a 2002 Ford Focus could find the high-side A/C valve but not the low-side valve needed to add refrigerant. The expert said to follow the larger suction line; the low-side tap is usually on that line near the receiver-dryer, somewhere along the line, or at the compressor suction side. Refrigerant should be added only from the suction side, and pressure should not exceed about 250 psi on a warm day because heat can raise high-side pressure and blow a line.
