2007 Ford Focus Locating engine air filter
2007 FORD FOCUS
78,000 MILES • 4 CYL • 2WD • AUTOMATIC
MATTASTIC
Can not locate engine air filter or cabin air filter
Jun 15, 2010 at 2:16 PM
RENAUDTN
  • 636 POSTS
Your air filter is inside the air filter box. Look for the big black air duct in your engine compartment: one side goes to the engine (throttle body), the other side goes to the air box.
Jun 16, 2010 at 8:30 AM
DSHADOWALEX
Well starting with 2006 and later models ford discontinued cabin air filters (in focus). As for the Air cleaner element, I have had issues finding it as well. I believe it's a 30K mile change filter. I recommend when you find it using a high quality filter like K&N or equivalent, as you may have to remove the dirt barrier under the front bumper to access it. Because of low clearance, you also may need to raise the car on a lift or jack it.
Jun 21, 2010 at 2:05 AM
