2003 Ford Focus Leak Detected can't ID?
CKAMHERST
  • 2003 FORD FOCUS
  • 4 CYL
  • 80,000 MILES
Positive that I have a Coolant leak actually dripping under Car around Oil Pan location. Would that be the Housing, Hose, or water Pump?
Thursday, April 1st, 2010 AT 7:52 PM
AMRAAM35
  • 39 POSTS
Could be any one of them. The way things are routed down there, the coolant could be leaking from one spot and running down something and dripping out at a different location. Recommend you try to trace the leak back to its original location. If you cant do that, wipe clean the engine and drive the car a short distance, and observe the leak again to try to spot the source.
Tuesday, April 6th, 2010 AT 12:34 PM
