2001 Ford Focus COOLANT LEAKAGE
ARCHKUM
Engine Cooling problem
2001 Ford Focus Front Wheel Drive Automatic 108000 miles
HI
There is coolant leaking from our car, but don't know from where. It doesn't leak everytime, mostly after a long drive when the car is at rest it leaks.
How do I find where is the leak from and how do I fix it?
There doesn't seem to be any problem of car overheating or smell or anything else. Thanks.
Feb 15, 2009 at 12:11 PM
  • 31,937 POSTS
HI there,
The first thing that you will need to do is get a cooling system pressure test done, this will help locate any external coolant leaks, your mechanic can do this simple test for you.
Mark (mhpautos)
Feb 15, 2009 at 6:21 PM
