Check engine light on
WRENCHTECH
  • 20,761 POSTS
You can't assume that is the problem. There are a dozen other reasons that code could set.
Wednesday, May 20th, 2020 AT 12:52 PM (Merged)
TAYTHEKING
  • 14 POSTS
The mechanics told me it was the actuator and they had a hard time looking for the part so they let me have my car back till they can find and buy the part somewhere. So I now have the opportunity to fix the problem myself after getting the free check up. Can you answer my question please.
WRENCHTECH
  • 20,761 POSTS
Being that it's an inline 4 cylinder car, I have nothing to identify bank 1 from bank 2 since it only has one bank. You can test the actuators with a hand vacuum pump to determine if they are working properly. As far as purchasing one, the dealer is the one and only place that I believe sells this.
FUELLENBACH
  • 6 POSTS
  • 2003 FORD FOCUS
My car is stressing me out. I've got a Ford focus ZX3 2003 with 80,000 miles which makes it right past the insurance coverage. The car as of late has been stuttering as it comes to a stop. Also! When driving from low to high speeds the car lags when shifting and has even stopped accelerating while on the freeway like the car switched into nutreul. Scary stuff. I have no Idea what is going on. No check engine light comes on and it is occuring more frequently.
I'm college with a budget of whatever is in my pocket. Help would be appreciated and I have heard that you guys were the guys to ask. Thanks.
Update. AAMCO just called me with a transmission check and said I'm leaking fluid through a pressure release valve. I don't know how long I have been driving with low trans fluid but hopefully damage to the transmission is limited.
Still excepting thoughts.
SERVICE WRITER
  • 9,123 POSTS
What is the level of your transmission fluid?
FUELLENBACH
  • 6 POSTS
Currently empty. As soon as AAMCO filled the trans with fluid and then drove it around the block for a test ride it was empty by return. I know, not good.
SERVICE WRITER
  • 9,123 POSTS
Uuuhhh, yeah.
So you do have an idea of what is going on.
Transmission fluid leak as a start and now a transmission most likely.
SERVICE WRITER
  • 9,123 POSTS
Fulenbach said:
How much is general transmission work costing? How much is a new trans for a 2003 Ford Focus costing on average so I don't get ripped off?
And should I go with warranty extensions?
Thanks for your help.
My opinion is to put in a jasper remanufactured transmission, it has a 3 year/75,000 mile warranty.
Before you do that you need to fix whatever is leaking. Then fill up the tranny and see how it goes, maybe you got lucky.
RANDY SHARP
  • 165 POSTS
  • 2003 FORD FOCUS
  • 65,000 MILES
This is a follow up question the 2003 ford focus 2.3 litre it cuts out when idles and say the check engine light is off can you still retrieve the trouble code from the scanner, because the check engine light comes on for awhile then will go off but it still cuts out when idle?
  • 52,797 POSTS
Code readers will not pick up history codes. A regular scanner at a shop will do this
RANDY SHARP
  • 165 POSTS
What are history codes this has been happening for about a month or so, at first when the check engine light came on it quit cutting out then when it went out it cut out at idle again, but it only did that a couple of times but now it cuts out at idle light on or off, so why is that and why is the light go on for awhile and go off for awhile?
  • 52,797 POSTS
Intermittent failure. We need the code to figure which direction to go on.
WALVO
  • 2003 FORD FOCUS
  • 4 CYL
  • MANUAL
  • 41,000 MILES
Hello I have a Focus RS 2003 The engine management light has come on and the diagnostics kit said it was due to low intake temp, Now it has stopped coming onto boost and lost alot of power, any ideas what I sould do?
Cheers James
  • 31,937 POSTS
Can you post the exact codes set in the ECU?
Mark (mhpautos)
WALVO
I don't know the exact codes but when I took it to Graham Goode's the diagnostics said the engine management light was on due to 'low air intake temp'
2CP-ARCHIVES
  • 4,540 POSTS
  • 2003 FORD FOCUS
  • 66,000 MILES
A couple of months ago it started cutting out at idle only not stalling. The check engine light didn't come on for awhile, when it did come on, it quit cutting out it ran fine, then the light went out and it started doing the same old thing. But now the light will come on for awhile and it will go out for awhile. But it cuts out all the time now light on or off. Does anyone have a theory for this?
  • 52,797 POSTS
We need the code to start. It could be a missfire from plugs or wires or a vacuum leak from the pcv line
RANDY SHARP
  • 165 POSTS
I just put new plugs in it and it don't have plug wires it is coil on plug, and you are right I just have to have it scanned when the light comes on
2CP-ARCHIVES
  • 4,540 POSTS
  • 2003 FORD FOCUS
  • 92,000 MILES
Was driving car last week and engine warning light came on followed by auto tranmission light followed by red on tempreture gauge, took it to mechanic he stated that it could need head skimming and head gasket after looking at diagnostic machine, he then took it for a drive, came back, turned off warning lights and said it seemed that id been lucky and if it happens again to take it back to him, I then drove at a slow pace for five days then yesterday morning I took the car out, drove just over 60 mph, and the tempreture gauge went to red, auto transmission light came on followed by the engine warning light, drove home very slowly as car lacked power and was shuddering?
  • 52,797 POSTS
Scanners never tell you the issue. It gives you a direction of failure.
Get the codes and we will start
overheating may have damaged the head gasket now.
Suggest a new shop.
