2001 Ford Focus Transmission Fluid
67,000 MILES • 4 CYL • FWD • AUTOMATIC
JW0475
I recently noticed that my Focus was leaking fluid. It has had an issue lately with losing power steering fluid so I checked the reservoir first. It was a little low so I topped it off with Prestone power steering fluid that had a "stop leak" additive in it. After looking at the fluid on the driveway it had a reddish tint to it which I assume is the automatic transmission fluid.
What could be the cause of the leak? And, what should my next steps be with this problem? Can I simply get the transmission fluid changed which may fix the issue?
Thanks in advance!
Aug 10, 2009 at 1:27 PM
RACEFAN966
  • 5,029 POSTS
Ok so first you need to get the car on a rack so you can look at it from underneath. If the pan gasket is the leak then yes a trans service (fluid and filter change) will fix the problem. You will need to get a look at from the bottom side to determine the leak.
Aug 11, 2009 at 4:28 AM
JW0475
Thanks racefan966...I had the transmission fluid changed and the tranny checked over. The shop said the leak was not coming from the transmission but rather from the steering rack. They said it's about a $700 job. Does that price sound about right? I found the part online (remanufactured) for about $150. Could the labor really bring it up to $700?
Thanks again.
Aug 12, 2009 at 9:04 AM
RACEFAN966
  • 5,029 POSTS
Ok here is what I come up with. They are way overpriced from what I found. According to the time and the average labor charge it calls for 2.3 hours to change the rack unit at a cost of $172.50 and then it is another 1.9 to do a 4 wheel allignment (highly recomended) for another $142.50 for a total of $315. Now if you choose to do only a 2 wheel alignment that would cost $97.50 instead. I hope that helps.
Aug 13, 2009 at 3:53 AM
JW0475
Thanks again. My uncle's dealership gave me a price of around $450 parts included. They give me a discount or will let me use a rack to do it so I may save even more. Thanks for the input. Money's tight these days and it's great to have resources to turn to. I do all my brakes, oil changes, detailing and tune ups but am afraid a steering rack may be beyond my scope! Thanks again.
Aug 13, 2009 at 4:19 AM
RACEFAN966
  • 5,029 POSTS
No problem thanks for you support. It is all of you who keep us going. If there is anything else just ask.
Aug 13, 2009 at 4:26 AM
