how can i check the transmission fluid level
82,000 MILES • 4 CYL • RWD • AUTOMATIC
TYREE FOWLER
the transmission is not changing gears it is slipping.
Dec 16, 2016 at 2:05 PM
  • 31,937 POSTS
Your car has a DPS6 transmission and the clutch and transmission operation can only be checked with a Ford factory IDS scanner. you will have to get a dealer to test this problem first hand.
Dec 16, 2016 at 5:30 PM
