2000 Ford Focus turn signals
GENS05
  • 2000 FORD FOCUS
Electrical problem
2000 Ford Focus Front Wheel Drive Automatic
For awhile my right turn signal would come on by itself. Now my four ways come on by themselves, and whenever I switch my headlights from high to low beams and vise versa. If I jiggle the turn signal switch they turn back off, but sometimes it takes a little work (most of the time pushing it out and up a little works the best). Would this be a problem in the wiring in my steering column?
Friday, August 7th, 2009 AT 2:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Most likely it is due to a faulty multi-function (turn signal) switch on the column. It is a good idea to check the wiring first though to ensure there are no damaged wires touching, loose wires etc.
Friday, August 7th, 2009 AT 9:16 PM
