2000 focus hesitation on accel, studder in idle/cruise
2000 FORD FOCUS
SUPERSPORT396
Sitting at idle it'll studder every 30sec or so, stomp the gas and it hesitates then revs fine. Driving at 45-50 or so and barely touch the gas and it stumbles then takes off.
Tried injector cleaner, air filter, Same.
Tried plug wires, Same, tried plugs , cleared up completly for one drive, next day same thing, getting worse.
Took it to the ford place, said #4 missing, said bad wires, (just replaced them) changed them anyway, still the same.
One thing i've notice is that there is a arcing/ticking sound when the engine studders comming from the left side of the dash, tach?
Im thinking cracked #4 coil post arcing into the dash thru the tach wires. What do ya'll think?
Thanks
Aug 1, 2006 at 12:12 PM
SUPERSPORT396
2000 focus SE , auto, 107K on the clock.
Biggest piece of junk i've ever had.
Aug 1, 2006 at 12:16 PM
DSECK21
i would try ignition coil. I had the same problem with my 2000 se and that compleley fixed it.
Jul 26, 2007 at 8:51 AM
NANIMO
  • 11 POSTS
There are a few recalls, go to your local Ford dealership they have to fix all the issues completely free of charge. Read other questions on the forum for details.
Oct 21, 2007 at 11:08 PM
