1999 Ford Fiesta starting engine
SEWMAN
  • 1999 FORD FIESTA
Electrical problem
1999 Ford Fiesta 4 cyl Two Wheel Drive Manual
when I try to start the car I get a clicking noise and the engine wont start I have changed the starter motor and it still does the same.
Wednesday, July 21st, 2010 AT 3:51 AM
No crank at all/nothing/nada:
Could be the starter relay, clutch switch/park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Wednesday, July 21st, 2010 AT 3:58 AM
LIONEL1990
Im not good with this, but mine did the same. There is a thing right next to the starter that should boost the starter. That thing is broken, but cheap to replace. Hope this helps.
Thursday, March 24th, 2011 AT 8:23 AM
