1999 Ford Fiesta Car Blow Fan Heater
HOLBY
  • 1999 FORD FIESTA
Heater problem
1999 Ford Fiesta Two Wheel Drive Manual 55000 miles
Hi Guys,
The last week has been particularly cold and now I have decided to try and sort this problem out. The air vents on the dash board blow out cold air despite the setting being on maximum heat. I have removed and replaced the fuse with no success. The manual informs me that there is no other potential fuse space or relay for this.
I am no mechanic and desperatley need your help before my hands freeze to the steering wheel!
Thank you!
Tuesday, January 6th, 2009 AT 4:56 AM
DAVE H
  • 13,384 POSTS
Check coolant level is correct. At the back of engine you will see 2 hose pipes going through firewall into drivers compartment. Run engine to operating temperature. Check to see if both of these pipes are getting hot when you turn the heaters on.
Tuesday, January 6th, 2009 AT 5:07 AM
