1996 Ford Fiesta heater not working
62,000 MILES • 4 CYL • 2WD • MANUAL
GARY RAWCLIFFE
my heater only blows out cold air.any ideas?
Jan 9, 2009 at 8:00 PM
DAVE H
  • 13,383 POSTS
check the coolant level is correct .. locate the 2 heater core hoses (2x black hoses)which go through firewall in engine compartment to heater unit in passenger compartment ... run engine to normal operating temperature .. turn heater on to full heat and blow ... check the 2 hoses are BOTH getting hot to touch .. if not, check/replace thermostat and flush the coolant system with a good cleaner ... let me know !!
Jan 9, 2009 at 11:10 PM
