1995 Ford Falcon help
JOHNFROMTAS
Engine Mechanical problem
1995 Ford Falcon 6 cyl Two Wheel Drive Manual
i have a 95 ford folcon it seems to be loosing oil near the warter pump but ut dosent look to be the head gasket would it be the pump
Feb 14, 2010 at 1:38 PM
  • 31,937 POSTS
Hi there,
This will either be the timing chain tensioner which is behind the power steering pump at the top of the front engine cover, or the or the top timing cover seal, these often leak when the engine gets a few miles on it, trouble is the head has to come off to replace it.
mark (mhpautos)
Feb 14, 2010 at 7:02 PM
