2004 Ford Falcon ECU Codes
NUTS460
  • 7 POSTS
Electrical problem
2004 Ford Falcon 6 cyl Two Wheel Drive Manual
Is there a way i can look at the fault codes from the ECU without going to a mechanics. I know this can be done on some other cars by bridging out 2 wires on the computer plug under the dash and the fault codes show up by flashing the CHECK ENGINE light.
I have no problems with my car this is just for future reference.
May 8, 2010 at 2:56 PM
  • 31,937 POSTS
Hi there,
On the falcons there are 2 sets of codes and 2 test patterns, fast & slow codes and Key on engine off and engine running tests, you must use a suitable scanner to read these codes.
mark (mhpautos)
May 8, 2010 at 4:16 PM
