1993 Ford Falcon Steering problem
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
REXTON
I have a problem with my 93 EB 4L sedan with the steering, the steering wheel gets very stiff and lumpy when getting round towards full lock in either direction, the steering wheel is also stiff and lumpy when you first start the car for a couple of minutes. Aidditionally when you go full lock right hand down the power steering pump appears to stall momentarily. I thought the pump was the problem and changed it at the weekend but no change. Should also mention the power steering fluid had gone black. The way I see it there is only the pump, hoses and rack in the power steering system, so is it the rack ??? Would welcome any advice,
rgds
Rexton
Jul 20, 2009 at 8:50 PM
  • 31,937 POSTS
Hi there,I would be thinking that the rack will be the problem, but to be sure drop off the tie rod ends and make sure that you don't have a seized ball joint, make sure that the stub turns freely back and forth.
mark (mhpautos)
Jul 20, 2009 at 11:21 PM
