1964 Ford Falcon
DANIEL__CHAVEZ
Shakes or Wobbles problem
1964 Ford Falcon V8 Two Wheel Drive Automatic
Got the engine replaced with a rebuilt 302. Worked fine. Replaced the transmission with a new one my self and now it shakes really bad past like 40 miles per hour. Weird thing is that if it is in park or neutral and i rev the engine up it does the same shaking. So im doubting it is the transmission now. It is more like a washboard vibration What can this be?
Jan 24, 2010 at 3:53 PM
  • 31,937 POSTS
Check that you have the ignition leads correct, also check that you have not got a lifter problem, check usually tune components, what type of induction is it running?
mark (mhpautos)
Jan 28, 2010 at 7:40 PM
