Gear shifting
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROHAN KING
The problem is finding and shifting into fourth gear and after driving for a while, sometimes reverse, have not tried anything myself as I know little about cars.
Drives pretty well other than that. Is supposed to locate fourth gear at around 80 kmh but keeps going to 100 kmh without finding it and rpms sit between 2500-3000 rpms. Thanks
Feb 20, 2017 at 11:50 AM
  • 31,937 POSTS
I would start with making sure that the oil level is correct, just to clarify one point, are we talking about an Australian built FG Falcon?
Feb 20, 2017 at 4:34 PM
ROHAN KING
All levels look fine, yes Australian built BF MkIII.
Feb 21, 2017 at 4:24 AM
  • 55,746 POSTS
Hey ROHAN KING.
Please connect a code reader to the car to see if any transmission sensor codes come up, here is a guide to help you get the codes.
Please run this test and get back to us so we can continue helping you.
Best, Ken
Feb 23, 2017 at 7:37 AM
  • 31,937 POSTS
You do need to check at normal operating temp, running in Park, the oil should just drip out the side plug, is this how you checked the trans oil?
Feb 27, 2017 at 7:14 PM
