Vacuum Diagram
LWILLIAMS
I have a 2006 Ford F-350 Power Stroke Truck with 6.0 Diesel it has about 50,000 miles on it. I am having problems with the air conditioner. It will not change from defrost to A/C. I was hoping someone knows a quick fix or could e-mail me the vacuum diagram.
Jun 14, 2007 at 2:08 AM
MIKE H R
  • 3,094 POSTS
3 transmissions? don't think all where bad, how is the drive axle where it goes into the transmission, is there any burs or is it out of round. if there is any high spots or ridges on the drive axle then it would make the seal wear and leak.
Mar 12, 2007 at 5:34 AM
BRUCE HUNT
  • 3,754 POSTS
I wonder how bad the damage was to the vehicle. For instance, I am thinking about the alignment of the engine with the axle. My point is I worry that the engine is pushed back on the side that was hit and is not running true. I could think of some ways to check or measure to see if the engine is not setting correctly. Just a thought. Could be a bent motor mount.
Mar 12, 2007 at 5:55 AM
