Ford F350 front end problems
MORETHANLUCKFARM
i have a 2000 Ford F350 4x4 Dually 7.3 diesel with 90000 miles. It would shake violently when hitting a bump make horrible clanging clattering noises and you could feel it rubbing thru the floorboard. it started out small but escalated on a 500 mile trip home. We have replaced the ball joints, stabalizer bar, 1 wheel berring, tires, had it balanced and aligned. when the lock out was locked, it made a horribly loud grinding noise that sounded like it was going to lock up the entire wheel. we took out the lockout (the same wheel that we put a new wheel berring on) and tried using the other wheels lock out, thinking it was a bad lock out. No luck! I have had this truck to 3 mechanics and i am only sinking more money into it without resolution. what do i do next? is there any place online to get a picture diagram of the assembly of the front axel and the parts associated with our problem. also a u shaped piece on the pass side moves freely when the lock out is not in & the driver side doesn't move. We were told that was normal while the lockout were not in. Is that correct?
Jul 17, 2007 at 11:07 AM
ASHLEY WILLIAMS
I'm having the same trouble on a 2000 f350. So if you figure it out please let me know and I will do the same.
Jan 17, 2011 at 6:30 AM
WYOBULLRIDER
Hi i was wondering if anyone found a answer to the problem with the 2000 ford f-350 4x4 dually 7.3 front end i just yesterday started the same problem with mine.
Jun 6, 2012 at 10:15 PM
  • 110,251 POSTS
Have you checked tie rods and the pitman arm?
Jun 25, 2012 at 7:39 PM
