Googling around a lot of answers suggest the ring and pinion are worn out. Can that happen in 33,000 miles?
1997 Ford E-350 Rear End Howl
The noise will only get worse but will not come apart for many miles. Let me know
How difficult is it to change out the pinion bearing?
If it was me, I would change the pinion bearing and align the ring and pinion. Make sure you buy a new crush washer for the pinion. You may end up with a little noise but nothing like you have. Good luck
Suggested Repair
Identify the axle from the tag on top of the housing. Have a Ford technician familiar with these rear ends replace the mismatched pinion bearing, realign the ring and pinion, and install a new crush washer. Some residual noise may remain.
Conversation Summary
The owner of a 1997 Ford E-350 Super Duty RV with 33,000 miles reports a rear-end howl under load that is quieter when coasting, plus a faint whir from a stop that becomes a howl above 50 mph. The expert says this is a common Ford issue caused by a mismatched pinion bearing and race, which can also leave the ring and pinion misaligned. The noise will worsen but the rear should not come apart for many miles. The advice is to identify the axle by the tag on top of the housing, replace the pinion bearing, realign the ring and pinion, and use a new crush washer, preferably with a Ford technician who knows these rear ends.
