2000 Ford F350 rest
ALPREUSSE
  • 2000 FORD F-350
Computer problem
2000 Ford F350 V8 Four Wheel Drive Automatic
can I rest set my computer without hurting anything, if so how can I do it?
Monday, July 27th, 2009 AT 5:12 PM
  • 110,182 POSTS
You can try disconnecting the battery for about 5+ minutes to see if that does it. If it doesn't, you will need a scanner to do it. Most nationally recognized parts stores will do it for free, so you may just want to go to one, ask them to scan the computer, and when they finish, ask them to reset it for you.
Also, resetting the computer will not hurt anything. If there is a problem that still exists, the light will eventually come back on.
Wednesday, July 29th, 2009 AT 12:25 AM
ALPREUSSE
Will reset setting the computer reset any programmers that I have installed on the truck?
Wednesday, July 29th, 2009 AT 2:42 AM
  • 110,182 POSTS
I'm not sure I understand what you mean by programers.
Wednesday, July 29th, 2009 AT 11:54 AM
ALPREUSSE
By programmers, I am refering to performance programmers.
Wednesday, July 29th, 2009 AT 1:17 PM
  • 110,182 POSTS
Resetting it shouldn't change anything like. I believe you'll be fine.
Wednesday, July 29th, 2009 AT 4:07 PM
