2005 Ford F350
2005 FORD F-350
PAMNT2000
Engine Mechanical problem
2005 Ford F350 6 cyl Four Wheel Drive Automatic
I have a2005 F350 6.0 liter diesel truck and a light that looks like a yellow wrench just turned on. I was wondering if anyone knew what that meant and if there is any way I can fix it. Thanks.
Dec 20, 2008 at 7:44 AM
DAVE H
  • 13,384 POSTS
The PCM has detected a fault on the electronic throttle control system .. have the cars pcm read for faults and repost with fault codes for further information
Dec 20, 2008 at 8:31 AM
PAMNT2000
[quote:41759cd139="Dave H"]The PCM has detected a fault on the electronic throttle control system .. have the cars pcm read for faults and repost with fault codes for further information[/quote:41759cd139]
Hey Dave thanks for the help...You say to have the pcm read for faults and repost with fault codes for further information but how is this done and will this fix my problem. Do you know if I need any special tool to do this on my own? thanks once again for your time. -Patricia
Dec 21, 2008 at 4:35 AM
