2000 Ford F350 clutch
PATTIEANDJOHN
  • 2000 FORD F-350
  • V8
  • MANUAL
  • 112,000 MILES
Suddenly wouldnot disengage. Never slipped. Replaced master/slave unit with prefilled unit. No change. Removed transmission and clutch. Pilot bearing was trashed. Clutch looked fine. Would the trashed pilot bearing prevent the clutch from releasing?
thanks,
john
Tuesday, December 23rd, 2008 AT 2:47 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Hi, did you have good pedal when the clutch would not engage?
Friday, December 26th, 2008 AT 12:17 PM
PATTIEANDJOHN
Pedal feel never changed. Driving and suddenly would not disengage.
Thanks,
john
Saturday, December 27th, 2008 AT 3:21 PM
KEN L
  • 48,363 POSTS
Hi, if the pedal never changed it sounds like the clutch disc lost a spring and could jam the clutch causing the problem you have described. Have you inspected the disc for missing springs?
Saturday, December 27th, 2008 AT 4:56 PM
