1999 Ford F350 Oil pan removal
PROGOLF64
  • 1999 FORD F-350
Engine Mechanical problem
1999 Ford F350 V8 Four Wheel Drive Automatic
Do you have to jack the engine up to remove the oil
pan on a F350? Pan has been leaking for a long time
Is there a gasket to replace or is it just sealant?
Might be able to install sealant after dropping pan.
Tuesday, December 2nd, 2008 AT 10:28 PM
IMPALASS
  • 3,112 POSTS
Hello -
Well, looks like you have to raise the engine, remove many things including the drive shaft and it even stated the transmission is raised.
It does look like it has a gasket and you are to use sealant also.
35 - Oil Pan Gasket 3L3Z6710AA
Use Silicone Gasket and Sealant F6AZ-19562-A or equivalent meeting Ford specification WSE-M4G323-A6.
I can attach how to do it though lengthy if you would like. You didn't specify the engine so I used the 5.4L.
If you do let me know your engine size and the 8th digit of your VIN, I can check if there are any possible recalls on your vehicle.
Tuesday, December 2nd, 2008 AT 11:00 PM
