1997 Ford F350
MIKEBECK
  • 1997 FORD F-350
  • V8
  • 4WD
  • 200,000 MILES
Transmission wants to stick in first gear. RPM runs up to about 1500 then shifts hard. Some times it will do this in second also but for the most part it happends in first.
Friday, February 27th, 2009 AT 11:38 AM
2CARPRO JACK
  • 11,533 POSTS
Has it been serviced? Good place to start. Also haev the PCM scanned for any codes it may have stored that pertain to the trans. It could be a sticky valve or solenoid in the valve body or possibly a bad signal from a sensor
Saturday, February 28th, 2009 AT 8:05 AM
