Brakes problem
1995 Ford F350 V8 Two Wheel Drive Automatic
Ford F350 diesel. No brake pressure - the pedal goes to the floor. Have replaced the master cylinder (4 times), have replaced the vacuum booster and have bled the system several times. When the truck is running, no pressure, the pedal goes to the floor. When the truck is off, the pedal is full. Any ideas on what I can do now?
Oct 4, 2008 at 9:04 AM
